run, rem or prog
I was told that if you power down a machine, turned the plc's key to prog and wait for the machine to fully restart, some glitches could be fixed. Thoughts??
I'll be one of the voices that say that: "A well developed and well maintained PLC program should not 'fix itself' on a power cycle. PLCs are not PCs, and the 'operating system' is specifically made to manage and it expects to be powered down from time to time."
I would add that IF powering down and repowering a PLC actually 'fixes' the problem, it should be investigated...because...what's to say that the same event might actually CREATE a problem. Both are the same mechanism.
RANT=OFF
Hello all , i just bought a plc 5 ,and changing the key lock switch does not put the processor in either run or program mode. I can only do this...
3,195
Can someone tell me if it is okay to switch from RUN to REM while a piece of equipment is being controlled by the PLC, or do I need to shut the...
4,145
I have this SLC 500 running a pretty vital piece of equipment, and it's in RUN... What I want to know is, if I turn the key to REM so I can hook...
3,594
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
78
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
173
