S110 drive temp to PLC via Profinet
Holmux
Oct 2013
Aalborg
279
Hi All
I am trying to find a way to get the motor temperature that I monitor in starter over on my HMI.
I start to get a feeling this was not intended to leave starter, do I have to go true the analog output on the drive?
Or can I read the temperature from a block in the PLC?
/Flemming
Hej Flemming.
I dont have experience with S110, but I do have some experience with G120. Maybe there is some similarity.
1. The profinet telegram has to be one that has more than 2/2 send receive words.
For example telegram type 352 on G120 gets you 6/6 words.
2. You have to set the parameters of the words from the drive to the data you want to transfer. On G120 this is set with parameters p2051[0..7]
Hej Jesper / LD
At the moment I am using a ET 200SP PLC with a SinaPos telegram(111) to control the drive, in starter it looks like I can add a second telegram to the drive.
My options are predefined (see picture) do I have to manually link the temperature to the telegram?
It looks similar but not identical to my experience with G120.
Yes I believe you have to specify what data is to be filled into the freely configurable telegram.
In telegram type 111, there are 12/12 words. That is a lot. Are there not some of these words that can be freely configured ?
I use the Siemens FB that allows you to read a list of 10 parameters from the drive - no change to the the h/w config or telegrams required.
Hi there. Even after studying some of Siemens' manuals and examples, I still can't make my motor move to the references sent by a GE PLC...
1,263
Dear All I have Sinamics S110 drive that I will use to control a conveyor belt in steps, I have a 10 meter long conveyor belt, on the belt I have...
1,119
Hi all, I'm having an issue where I was looking at the program made a change to one parameter downloaded the program changed it back to...
1,148
Dear Gents First a happy new year to all 🍻 I am playing around with a S110_CU305_PN controller and is trying to make it as automated as...
1,526
Dear all I am working on my first project with Starter, trying to connect to a S110 CU305 PN, I beleive I have read every single manual regarding...
4,115
