Sinamics S110 configuration
Holmux
Oct 2013
Aalborg
279
Dear All
I have Sinamics S110 drive that I will use to control a conveyor belt in steps, I have a 10 meter long conveyor belt, on the belt I have mounted 10 blocks with exactly 1 meter apart, I place a sensor that will detect each block.
Each time I activate a button, I would like to move the belt until the sensor detect the next block, and time is an issue, so I need to complete the step as fast as possible, so a sharp ramp up and down.
At first I thought this would be very easy, but the belt will slowly stretch over time, so the distance between my reference points will change, my first thought was to slightly overshoot the distance and stop on the sensor, but I might still need to adjust the distance over time.
Any good advice before I jump into this, will I need a PLC as well or can this be done using the S110 controller?
Any advice would be great :)
/Holmux
Dear Gents First a happy new year to all 🍻 I am playing around with a S110_CU305_PN controller and is trying to make it as automated as...
1,526
I have a system with a S110 and a servo motor. When the operator hits the emergency stops the STO function in the S110 is activated. But it seem...
3,496
Sir, At present i can write one parameter at a time, but how to write multiple parameter in sinamics s110 using SFC 58 in S7-300. And also...
2,384
Hi dear, I'm totaly new in S110 SINAMICS.. i have a question about S110 sinamics. Normaly u have a function block to read your position about...
2,284
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
