Maj. Toxido
Good day to all of you!
I have a hard time problem with S5 plcs, last night there is a power failure in the plant then plcs goes to stop when I check it I found out that the program is lost (erase) . So I download the program. Upon starting of machineries the PLCs shutdown again,when I check it online there is a problem in communication of the interface card(6ES5310-3AB11).Troubleshooting said problem I found out that the communication cable is eaten by rats . I fix the said cable, then upon I test the hardware status block of all the output and input the program is crashing. I try to run the inputs status block the program is normal but when I put now the output status block the program crash again. I try it again vice-versa the same problem occured! What would be the problem of it? I go nut with this type of problem
