S5-155U CPU 946 and panel Coros OP15
mechanizator
Mar 2007
Brzeg
Hi everybody
I would like to ask you for an advice - I have a problem with connection between OP15 panel and S5 155U CPU 946.
We had line that was managed by PC with multiplex card and Dallas Semiconductors key for parallel port. Key is broken, so we were thinking to replace the PC and put one OP and make simple software to manage the alarms and I/O of plc.
Because for OP77B we had to wait until 29th of september, we want to use OP15 connected by AS-511 protocol.
We don't have cable 15-15 pin for this protocol. I downloaded one scheme but for OP17 cable but it seems not working - PLC not found is present on the OP screen.
I don't know if there are any additional FB to add to plc program to make the communication, or only the cable is enough?
Maybe someone can write me the right cable PIN configuration? Or maybe someone knows what else I need to modify to start to communicate? Last year I connected OP7 and 115U, but it was much easier - only a need to add FB51, DB51 and some modifications of OB21/OB22.
Here in present software exists FB52, but I hope it has nothing common with it.
Please help me, because we have the line stopped.
Hi, I've got a fault I've never seen before in that the Plc has a ZYK error on the front panel but the cpu is still in green. No outputs are...
1,520
I have a problem with S5-155U, Cpu 948. But when i delete the entire PLC using Step5 Run Led is on. But BASP Led is still on.(Steady) I...
3,104
Good day to all of you!:) I have a hard time problem with S5 plcs, last night there is a power failure in the plant then plcs goes to stop when...
5,960
I have S5-155U, Cpu 948 It has become difficult do normal reset after power off. Can anyone help me with this one?
2,917
Our customer has a S5 155 that has a Canbus card in the central rack. I only have a picture here, and cannot see the device number. I don't see a...
1,892
