S7-1200 and database
Ahmed Najeeb
Dec 2015
Riyadh
HELLO , i am automating production plant using s7-1200 (TIA portal v13) and wincc comfort advanced the function and the linking with SCADA system is going well , what i need to ask for i want to creat a database and extract data of my PLC to be saved and called to print or reporting upon the operator request , so how to do that . i really need help i have been searching and trying for a long time with no progress .. thanks in advance
WinCC comfort & advance have some data logging and reporting capability, but if you have a SCADA system already, it probably makes sense to do any DB/SQL there.
Hey there! I've got some questions/problems with the tia portal v11 and the PLC s7-1200. I don't know how to log my data into a mysql database...
11,497
I need to build a 100 records database inside an AB model 1200. Does anyone knows how to do this or has a small sample project that will allow...
3,299
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
59
35
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
