S7-1200 and Red Lion HMI, any issues?
Dr_Watson
Nov 2010
Ohio
I am considering using the S7-1200 for a small pressure vessel application, along with a Red Lion G306. The plan is to use the G306 for data logging, primarily temperature and pressure.
I was just interested in knowing if anyone has had experience integrating the two and how that experience went?
First post by the way, hopefully not the last, thanks in advance.
You have to use the S7 300 driver
You have to address as dbx.dbx and dont use smbolic addressing in your 1200 program
Also an issue with timers and counters if i remember correctly
I dont think Redlion have done a driver that works 100% yet
Thanks for the information, I may consider using the Siemens HMI then and see if I can't get away with Siemens web server for data logging.
As far as issues with timers and counters I will have to look into that, so thanks again for the heads up, if you can point me in a direction that might give me more info on those issues it would be greatly appreciated.
504bloke is correct in that you would use the S7300 driver and you need to turn off the symbolic addressing in the PLC. This will provide access to the DB registers in the PLC.
Jeremy
With regards the timers and counters, you cant get the data from them with the redlion driver addressing a timer or counter direct as in an S7 300 for instance
All you have to do however is move the Timer data that you want into a register in the S7 1200 and access this from the Redlion G3
Now i would recommend you use a G3 for this personally and just suffer with the little bit of cumbersome programming
Redlion: When will the 1200 driver be out ? I'm sure (may be wrong) others are offering it (but without symbolic) with timer and counter access ?!?!
I have used the 1200 HMI's (only once) - They are SHOCKING in my humble opinion, ok to program as its in TIA but they are rubbish to use compared to a G3
Ah, thanks for the info, I am hoping to get a 1200, and a G3 from a local distributer on loan here in the next few weeks for testing.
Hi All, I am hoping someone can help. I have setup a Red Lion Data Station (DA30D, Crimson 3.1 Build 3112) to log data from several Allen...
18
7,370
I'm working with the combination of a Micrologix 1200, a Data Station DSPSX000 and a Keyence SR-1000 scanner. My code in the data station is...
3,030
Has anyone tried to use a HMI with S7 1200 that is a third party. I have Red Lion Control device I would like to use with S7 1200, I cannot...
7,992
Hi First post here! I admit I am not too used to handle interrupt OBs in Siemens. I have a customer who has been buying a standardized solution...
255
Hey guys! Newbie here, have some experience in both S7 Classic and TIA V13, but would really like your opinions/help on a solution...
37
25,240
