s7 1200 and winCC flexible advanced
rQx
Oct 2010
Trelleborg
1,051
Hi!
I shall connect my s7 1200 CPU with a computer. I have wincc flexible advanced and I have made my program. I found on the siemens site how to configure the ethernet connection in WinCC Flexible Advanced. Is there anything I must do in step 7 to make this work? The CPU is at the customer so I can't try to figure it out by trial and error. Grateful for answers / Tim
No experience with S7-1200, but if you can define the connection on the HMI side by pointing out the S7-1200 CPU as the target, then that means that everything is taken care of - probably ;)
This is one of the things that the new TIA Portal should make easier. The setup of connections should be bulletproof.
N.B. For the final HMI application, wether a panel of a PC RT, you may have to setup the intended ports IP address manually on the panel or PC.
For a PC RT, you may also have to setup the PG/PC Interface to S7ONLINE=TCP/IP (adaptername).
Be sure you only access non symbolic DB's in the 1200. Check Link ID 38111886 on the Siemens support site.
Hello! I want to save production data in a list form. I have three variables that I want to save: Product, weight and time. I want this to be...
3,859
Dear all, I nead to access parts of structures from s7-1200 plc in wincc flexible running on PC. My problem is that plc programm is done by...
2,950
Hello all, I am trying to connect an existing Siemens WinCC SCADA to a new machines S7-1200 PLC. I have connected anpther 1200 and a 1500...
2,881
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,570
Hey folks... I've been thrown into the deep end of a dodgy pool. A life line would be appreciated. Our one and only resident PCS7 knowledgable...
4,057
