s7 1200 & cpu 1215C doesnt work
nwzt
Oct 2016
turkey
hi every one,i am a new member.
in my working factory,our device does not work.
i chose the interface and subnet ,but system does not work and nat show any thing below area
thank u everyone.
I would look at the 'Connection to interface/subnet', I have never used Direct at Slot, I think I always use some version of PNIE.
Try Disabling your firewall and antivirus software, I can't browse any CPU's with those enabled in our factory network.
If this system has an internet connection then you will have a problem. IP 160.0.0.110 isn't in the list of private IP addresses and resolves to a location in the US. Web search for 'private ip address ranges'.
Our factory has used this ip adress until the now.There was not any problem so far.
We send the ping from computer to plc,and it give response as i said.but system does not work.
try to telnet to port 102. That's what I've always done to verify that the firewall isn't blocking the S7 download port.
if it succeeds, it should go to just a black window, with no command prompt or anything.
Hello guys, I am new to the forum as well as to the Siemens PLC programming. So the problem that I am currently facing is to link S7-1200 1215C...
1,996
Hello everyone :) I just want to start with learning PLC programming, so I need advice. I have SIMATIC S7-1200, CPU with integrated memory...
950
Hello I have 1214C DC/DC/DC CPU which I can't communicate with it through pc. When I'm Trying to search the cpu in tia portal I can't find it...
1,499
Hello experts, I have purchased a used SIEMENS SIMATIC S7-1200 CPU (6ES7212-1HE40-0XB0) with a SIEMENS SCALANCE M876-4 (4G-LTE) ROUTER...
1,995
Hello all. I have just recently got a S7-1200 F CPU and safety licence and I am trying different things. So far I've tried monitoring of...
2,628
