S7-1200 cpu hardware malfunction
Hossamhegab
Sep 2019
Cairo
23
Hello
I have 1214C DC/DC/DC CPU which I can't communicate with it through pc. When I'm Trying to search the cpu in tia portal I can't find it.
The plc was working properly but suddenly it's status lamps goes as following
Run/stop flahes green and yellow
Error lamp is always red
Maint lamp flashes yellow
Also when I connect ethernet cable between pc and plc
Link lamp always green
RX/TX always off
Any help will be appreciated.
You can try an Extended Go Online.
But the most likely answer is that the PLC has failed, and that no amount of going online will fix it. If this is the first time that one in the machine has failed, it could just be bad luck. If others have failed then you need to look at protecting the PLC from voltage spikes.
I agree trying to go online is pointless. Are there IO modules connected to it, if yes then remove them and try restarting it.
Either way if you have or can get a hold of a memory card that would be your best bet a trying to reset it and hope that gets it going.
Hello everyone :) I just want to start with learning PLC programming, so I need advice. I have SIMATIC S7-1200, CPU with integrated memory...
934
Hello experts, I have purchased a used SIEMENS SIMATIC S7-1200 CPU (6ES7212-1HE40-0XB0) with a SIEMENS SCALANCE M876-4 (4G-LTE) ROUTER...
1,993
Hello all. I have just recently got a S7-1200 F CPU and safety licence and I am trying different things. So far I've tried monitoring of...
2,599
Hello guys, I got 6 PLCs with in same network for example 10.80.x.x One of these PLCs is S71200 which I'm trying to use as RTU, its IP address is...
1,145
Hello, I’m developing a program and i found that my simulation works very well when i use CPU 1500 but when i use 1200 and i click download. A...
1,938
