S7-1212c
sentano
Dec 2009
Ontario
16
Hi all,
Is it possible to monitor/manage the S7-1200 series over the internet?
Any help is greatly appreciated.
Thanks,
Alex
The S7-1200 series PLC's have an on-board ethernet (profinet) port, so as long as the network that the PLC is on has access to the internet you should be able to connect remotely. The real question is the layout of the network and your level of access (local / remote) to that network and the PLC.
Thanks,
So if I have a modem and a router and the s7 at one end, as long as I know the WAN IP to look at, I should be able to find my processor. In this particular case I'm not looking at complicated network layouts, the idea is to be able to troubleshoot the rig (mobile rig), from the other side of the world, without having to travel.
Cheers
Apparently the web server will be available in the future (if it is not already), so you should be able to write web apps that sit on the CPU like you can on a Simotion.
This is correct. The web server is not yet available but will be supported in a future version.
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,896
Hi Guys, I am aware that the S7-1200 series on their right side have an I/O expansion port. Like this...
1,583
Hi there, I'm using an S7-1200 system and I have followed a Siemens application example to read/write data to 1x slave using Modbus RTU and a...
4,190
Hi there, I would like to use an S7-1212C to act as both a Modbus TCP Client and server at the same time. I'm gathering data from generator sets...
1,361
Hello everyone ! I am using a siemens PLC 1212C AC/DC/RLY to simulate a PLC program on TIA Portal V13. Each time I come online and monitor I get...
2,593
