S7 1214 Web access
Cjohan
Sep 2020
Peterborough
31
Good day
I have a Siemens 1214c DC/DC/DC and i have created a program, i have activated the web server access in the properties of the plc. I also called the web server FB in the main OB1 and i have generated the DB blocks 333 .
I also have told it exactly what folder to look at and selected the HTML file .
I connect the PLC to the web and i cannot see the plc with just typing in the ip adress
am i doing something wrong ?
I have also watched the videos on youtube and still cant view my PLC
i have also tried to view it from my phone and also that is not working
anyone any ideas ?
Have you given the PLC an IP address and set it to use Subnet? Have you set the Subnet mask? Both of these are under Profinet Interface / Ethernet Addresses. Is the IP address you have given the PLC and the Subnet mask in the same range as the Computer and Phone you are using? How is your computer attached to the network? How is your phone connected to the network?
I'm a beginner at this, I have points with x y z coordinates that I want to record on s7-1214 and use to move the axes for those points. How can I...
41
Hello I have a siemens 1500 connected to a redlion DA30 I use the redlion to write an operator entered number (retained) to a register in the PLC...
1,782
Hi there, I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol. I downloaded...
2,061
hi i want to know that do can use s7-1200(cpu-1214) for the following specifications: 45 DI 30 DO 20 AI 1 port ethernet
1,527
How to stop error led of siemens plc 1214.
2,071
