beethoven_ii
I have set up comms between an S7-1512SP-1 PN plc programmed with TIA v17 and an S7-314C programmed with Simatic S7 using GET and PUT blocks in the S7-1512 cpu. There is an existing communication set up with another S7-315 plc using GET and PUT blocks which works fine. Both communications have been done using an S7 connection to an unspecified partner. I have a watchdog counter between my 2 plc's and it works but regularly stops communicating every minute or so and takes anything up to 2 minutes before it starts working again. Sometimes it restarts quicker but the timing varies. I realise there may be site network issues which may be contributing to the problem but on continual ping from a command prompt I can connect to either plc in 1ms or less on a regular basis. All the settings in my new S7 connection look the same as the existing one that works, other than the hardware ID which is of course different.
I'm just wondering any anyone has had similar problems and found a resolution in comes between an S71500 cpu and an S7-300?
