S7/200 24vdc ? on the 110v model?
geniusintraining
Jun 2005
SC
8,287
Hello everyone,
I want to buy a S7/200, the ones I have are 24vdc, I am looking for a 110v and know that the part numbers tell you the voltage (ie xxxx xxx-x(A/B)xxx-xxxx) so A=24 vcd and B=110v
So now to my question if I buy a 110vac do they have built in transformers? some others do GE, AB, Mit but some others don't AD (model dependent) so I was wondering do the S7/200 110v model have and 24vdc output?
Or does anyone have a link to the manual or wiring guide
Many thanks
Mark
Hello Mark;
Here is a link to the S7-200 system manual; if it does not provide all the required answers, come back to the forum:
http://support.automation.siemens.com/WW/view/en/1109582
If you look in the appendices, in the CPU technical specifications, you will see that the models wirh part no. 6ES721x-xBD23-0XB0 have AC power, DC inputs and relay outputs. So you can probably use the outputs as required in your projects.
Hope this helps,
Daniel Chartier
dchartier said:
Hope this helps
VERY MUCH...
Do you know how many Google pages and Siemens pages that I looked at, looking for that :) and I even search here (bad idea)
Thanks,
Mark
Is it possible to program this plc to put out less voltage through one of its outputs? For example, can the output put out 1vdc, then a timer, and...
2,296
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
70
44
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
149
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
291
