Ingeni@rio
hi guys,
this is my first post on this forum and hopefully not the last
I am a mechanical engineer trying to learn as much as I can abou PLCs and need your help in my learning procress...
I`m working on a project of replacing old relay logic (cca 30 relays+5 timer relays) automated hydraulic press for pressing paper moulded fiber cartons with S7 200.
I made a ladder logic for controlling the press and would like to replace start/stop switches placed on switchboard doors with OP panel.
The reason is that in that way I will need less DI(primarily for manual work mode) and also hope to learn winCC Flexible in the process.
Now I have seen in some programs that programmers use V-bit instead of M-bits for an ON/OFF function on panel.
Can somenone please elaborate what is better and why?
