S7-200 Cpu 226 port problem
isteak007
May 2009
NewYork
216
i have a S7-200 cpu 226. it has 2 port. port 0 & port 1.
but port 0 is not working (hardware problem). So i cant communicate with this PLC. but i have to download the program from PLC.
So how can i download the program from this PLC where port 0 is not working?
It is possible that the port is configured for "Freeport" which means you cannot go on-line while the PLC is in run mode.
Try placing the PLC to stop mode and see if you can go on-line.
If it is an actual bad port I'm not sure what to do.
Hopefully someone else on here may offer a solution.
i think port 1 is bad but port 0 is ok...
How can i communnicate with cpu 226 from port 1?
You can use either Port for programming, I regularly have an HMI connected to Port 0 and program using Port 1. Tell us what error message you get and maybe we can help.
Its a S7-200 part # 6ES7 216-2BD23-0XB0 A customer sent me one of these to extract the program out of. I have zero experience with Siemens S7...
2,238
Hello everyone, I have inquiry for Siemens S7 200, CPU 226 CN. Its for Chinese market. Can anyone tell me how exact to take data from PLC? I've...
2,651
hello once again im here asking a beginner question does anyone know how much current does the internal power supply (24v)from the siemens s7...
3,690
I have a problem, it is a modem connection between S7 200 and Westermo TD-32B with PPI cable (6ES7 901-3CB30-0XA0). I want a PLC which is a place...
2,664
