S7 200 outputs
Farid
Jul 2004
UAE
79
Hi every one,
I have an application where I have to connect S7200 PLC DC outputs to a drive that only accept NPN signals..
does anyone knows, whether siemens s7 200 has NPN transistor output or not..
I am planning to buy S7200 CPU 224XP..
thanks for your comments.
NPN/PNP!!!!
You can generate output from PLC to switch on a relay, then you can feed either 24V DC or 0V through NO contact of relay to drive.
Hi Farid.
I think you should take a good look at the Drive manual, because all the drives I worked over the years, you can change the inputs from NPN to PNP.
@Farid
S7200 in DC/DC/DC models only offers sourcing (PNP) outputs.
Keyence offers a dandy product (standalone) to convert NPN>>PNP. Works on 24VDC and offers acceptable (can not recollect) responce times.
www.keyence.com.sg
Email me and I will get you the part number if the web search fails.
Cheers
Hi Guys. I got a 1212C DC/DC/DC with 4 PWM outputs. I thought by adding an SB1222 atop of the CPU would give me more PWM outputs... but...
2,205
Maybe I'm getting confused because of all the topics on XIO/XIC or NO/NC instructions but I'm just looking at my PLC relay outputs on my...
4,310
When I go into the output datafiles I cannot see the two additional 1762-OW8 output modules. Do I need to initialize them or something for a new...
1,283
Hi all This is my first post, I've started to program a Micrologix 1200 PLC and I don't understand how relay outputs work. For example, If I...
3,083
G'morning gentlemen. I have been lurking on the forums as a guest for a while and had some queries which needed help. Overview: I am a absolute...
3,501
