S7-200 Printing
Gazzr
Nov 2006
UK
64
I would like to try and set up a S7-200 to print some text directly to a parallel printer. I have found some tips from Siemens website and a sample program to acheive this.
Only problem is I don't have a PPI cable ( I do but it is USB version). Can MPI cable be configured via adaptors? Or am I asking a really stupid question?
Also, the only tips I can find are regarding Parallel printers. Can the units be set up to communicate with serial and/or USB printers?
Can't really justify purchasing the cable for this trial, but if I can get the system working and prove the idea, it may then warrant it.
Many thanks.
Hello Gazzr;
Tip 19 (for parallel port printing) is for a "deviant" case; normal printing procedures are for communicating with serial printers in freport mode; the XMT techniques are covered in the S7-200_e.pdf manual.
You can use the USB version of the PPI cable without a problem (just assign the correct COM port).
Hope this helps,
Daniel Chartier
Thanks for the info. Presumably I need an adaptor to go from USB "Plug A" to "Receptacle A" or to "Plug B" to go straight into a USB printer?
Sorry, just re read my post and it sounds a little "odd". What I mean is my PPI cable is RS485 at the PLC side (Obviously) and the USB side is USB type "A" plug. But USB printers usually have a USB "B" style receptacle on the unit. Can an adaptor be obtained to get these two together?
Hello everybody. I need to print temperature data every 30 seconds. For this I need to print on a thermal printer that is connected to a CM1241...
1,473
Hi, I have an AB Micrologix 1200 connected with a Zebre TLP2844. Please I need help at printing barcode labels from a Micrologix 1200. I need...
6,656
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
61
37
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
144
