S7-200 Simulator v2.0
jairus
Aug 2010
Busay Cebu City
47
Hello Good day to all. I am a new PLC programmer, and I need your help dealing with S7-200, because I need to run my program with S7-200 simulator v2.0, before I will download it to actual machine. Is there anyone can help me how to use this simulator?, because I can’t find the .awl file for this simulator. Thank you in advance.
good day, first you need to open your s7 200 microwin software 3.2 then start do your program exercise and after complete your program you have to go to file look the export choose your file name and then press save. when you done you need to open your s7 200 simulator press the program you can see load program start load program choose which version of software you are using then press accept you will find your save program as awl.hope it will help you
Thank you nerraw, this is what I'm looking for, now i can download the program to the simulator in awl file not in mwp file.
Hello Good day to all. I am a new PLC programmer,I try to simulate a program, use the quick counter the May S7200 simulator rejects this instruction with a massage (an un-recognised instrucon in the program,that is not implemented in this version. The PLC has been placed in STOP. Instruction : HDEF 1,0)so i need help
hello.. I have tried in actual 2 years ago, not in simulator with this type of CPU S7-200, CPU 226 ; 6es7 216-2bd21-0xb0.
i used: mode-9, hsc-1, and input I0.6, I0.7, I1.0, I1.1
this is a a/b phase quadrature controller. now this project is still running for positioning application.
I'm not really particular with this simulator because this is not from siemens, this is a third party software, this won't work even with data block i think.
for more help. pls. click the link below.
http://fa.jonweb.net/Siemens/images/Article/Technical/HSC.pdf
Good Day guys I'm new to this forum, I have an XG-X2200 system and 2 cameras CA-HX200C. For example When I try to use a characterize of Vision...
1,421
Hello again for all wonderfull people around the world who anctios to help Here!! Where can i download a free simulator for siemens plc To check...
1,935
hello is what you use the simulator s7 200 microwin? it works perfectly. but if we add an input / output card, when loading the program will have...
2,262
Hello all. My first post here ever. What am I missing here?! I have made a simple FC that I would like to test out. I call it in OB1 and passes...
1,322
I want a simulator for s7-200 plc. While programming using status charts the ordinary simulators are not performing well. Can anyone suggest me a...
1,367
