S7-200 V memory
Edwinsky
Apr 2005
Pasig CIty
34
This morning I uploaded the program of our form fill and seal machine with s7 200 cpu 216 intalled on it. I save it on pc, swapped 2 inputs (edit offline)on program and hardwire due to damaged input. When i dowloaded the proram i noticed that the parameters (angle, positions) monitored on touch screen are all zeros. I restored this pameters manualy on touch screen. my question are how can i download program and save with this parameters which in Vmemory i think. Is it similar to N7 of AB? Can i monitor this change and value online. Is it in Data Block? Im using MicroWin V3.2.
Thanks in advance.
Edwin
There are 2 memory areas on the CPU (RAM and ROM).
While download or upload the blocks will always be taken
from the ROM area.
All changes to the V-Memory (no matter if retentive or not)
will affect only the RAM area.
So if your DB has a init value 0 and you upload the DB on
a later Point the value will be still zero.
To avoid that you have 2 options.
Microwin:
Before upload use the option "Create DataBlock from RAM".
All RAM values would be written persistent into ROM.
UserProgram:
You could use the SMB31 and SMW32 to store a single memory
address into internal eeprom(ROM) at runtime.
Alternate you coud use follwing library to store a range of addresses.
http://www.s7-200.net/Scripts/entry.php?entry_ID=2&Part=1
I have a product that uses a Siemens Simatic s7-1200 PLC. My company did not write the PLC program, but we have the program on an SD card. We...
2,265
What type of internal memory does the MicroLogix 1200 Ver.C have? In the documentation, there is only an internal non-removable battery for the...
1,595
Hi Guys, Is there any way of compressing the "Work Memory" of a Siemens S7 1200 CPU. I did change the installed card from a 4mb to a 12mb. I...
9,106
Hello! I am using S7-1200 PLC 1212C AC/DC with configured Modbus TCP Server. I can already read/write Inputs/Outputs (Coils) and Memory Words...
3,053
Hi we currently have a Micrologic 1200 running an automated saw program. If I plug in a memory module will it automatically write the program to...
1,291
