S7-300 alarm buffer
exmore84
Feb 2011
Diest
Dear members
I need in step 7 a alarm buffer. I made a little progam (See below) but it doesn't work. So if i get a alarm in DB110.DBW84 and M100.0 is set the alarm is transfering to DB1.DBW0.
When there is a new alarm and M100.0 is set to one, the data in DB1.DBW0 is transfered to DB1.DBW2 and the new alarm is Transferred to DB1.DBW0. I test the program in S7Sim but it doesn't work. Do someone know the problem?
A M100.0
OPN DB 1
L DBW 6
T DBW 8
L DBW 4
T DBW 6
L DBW 2
T DBW 4
L DBW 0
T DBD 2
L DB110.DBW84 <== This is a db with my alarms.
T DBW 0
If I understand you correctly, you want this only to happen only every time M100.0 shifts from 0 to 1.
A M100.0
FP M100.1 // Shift only on positive edge
JCN L001
OPN DB 1
L DBW 6
T DBW 8
L DBW 4
T DBW 6
L DBW 2
T DBW 4
L DBW 0
T DBD 2
T DBW 0
L001: NOP 0
Kalle
Loads and transfers are executed without regard to RLO. You need to use conditional jump to avoid execution of loads and transfers.
Edit: Kalle beat me to it.
Yes yes it's working. But i've changed the opn DB1. If i use this OPN instruction it doesn't work. Is this maybe because the S7sim?
A M100.0
JCN L001
L DB1.DBW 6
T DB1.DBW 8
L DB1.DBW 4
T DB1.DBW 6
L DB1.DBW 2
T DB1.DBW 4
L DB1.DBW 0
T DB1.DBD 2
T DB1.DBW 0
L001: NOP 0
Thanks by the way. It's a problem lesser in my project. Now i've still got one problem :( in winCC
Here is the modification required to "make it work"
Code:
[FONT=Arial]A M100.0[/FONT]
[FONT=Arial][COLOR=red]FP M100.1 // Shift only on positive edge[/COLOR][/FONT]
[FONT=Arial][COLOR=red]JCN L001[/COLOR][/FONT]
[FONT=Arial]OPN DB 1[/FONT]
[FONT=Arial]L DBW 6[/FONT]
[FONT=Arial]T DBW 8[/FONT]
[FONT=Arial]L DBW 4[/FONT]
[FONT=Arial]T DBW 6[/FONT]
[FONT=Arial]L DBW 2[/FONT]
[FONT=Arial]T DBW 4[/FONT]
[FONT=Arial]L DBW 0[/FONT]
[FONT=Arial]T DBD 2[/FONT]
[FONT=Arial]L DB110.DBW84 <== This is a db with my alarms.[/FONT]
[I][B][FONT=Arial]T DB1.DBW 0[/FONT][/B][/I]
[FONT=Arial][COLOR=red]L001: NOP 0
[/COLOR][/FONT]L DB110.DBW84 actually executes as
OPN DB110
L DBW84
The matter is im facing a BB alarm while i try to communicate yaskawa A1000 & S7-300 by profibus PPO type 5 method. I have changed my first...
3,120
Hi Everyone, I want to know how we show the profibus slave alarm in wincc flexible 2008.when any one profibus slave do not communicate or give...
3,665
Hello everyone and thanks for checking my post. I’m a beginner in PLC programming (still in school) and I’m tasked with doing a monitoring of a...
2,285
Hi All I'm using an S7-315F 2PN/DP with a siemens HMI (currently on a PC -WinCC flex) to control a small plant. If a plant process variable...
4,569
Good day all. Yesterday I had to upload my PanelBuilder 32 program from one PV and download it to another. They are cat#2711-M3A19L1. The PLC is a...
24
7,984
