Hi I've got very strange problem.
I have a project for CPU 317-2 DP.
1.I download hardware config to PLC - it's ok.
2.I download OB1 with contents
L 0
T MB2 - it's still OK.
3.I go online in OB1 - PLC stops and diag buffer says PLC Defective.
This happens in PLCSIM (5.4+SP6).
I've found this in diag buffer (attached):
How can I find the source of error ?
I'm linking the project file to dropbox as it's quite big multi-PLC (5 MB).
https://www.dropbox.com/s/9usdb4utvxi1bs0/Calc_6.14.zip?dl=0
It's the plc named Sivacon.
I'm really confused. I'd be really glad if someone could point me in the right direction.
L 0
Code:
Event 9 of 10: Event ID 16# 530D
New startup information in STOP mode
Startup prevented by:
Loading user program or internal inconsistency detected
(SDBs less than 200 incomplete, superfluous, or incorrect)
- STOP request exists
- Keyswitch set to STOP
- Cold restart or warm restart necessary
Startup information:
- Time for time stamp at the last non backed up power on
- Single processor operation
Current/last startup type:
- No startup type/following memory reset
Permissibility of certain startup types:
- Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary
- Automatic startup not permitted, corrections in parameter assignment, submodule, etc. necessary
Last valid operation or setting of automatic startup type at power on:
Operating mode: STOP (internal)
Incoming event
07:47:42.668 PM 08/01/2016
(Coding: 16# 530D FF04 C777 0161 0000 1100)
