S7-300 Software Redundancy
recycled_mind
May 2007
Cebu, Philippines
118
Dear Experts,
I am working on a system with S7-300 software redundancy due to high availability requirements of the control logic. My question is, can I do it with a single profibus network? I came to this question because there is a DC drive with profibus interface that is controlled by the PLC system and should be online always on either station A(master) or B(back-up). Need some inputs on this issues.
Thanks,
Alex Senagan
Republic of the Philippines
how would you achieve any communication redundancy with just 1 connection ?
Redundancy is a generic term that need specific definitions. You can achieve plc redundancy only with your setup (not i/0 and device) but it is useless since parts that is more willing to fail is probably i/os...
Real and complete redundancy is made using s7-400h
you have to use a Y-Link [FONT=Arial, sans-serif] 6ES7197-1LA04-0XA0[/FONT]
Is a module that connects two segments profibus coming out with a single cable
Hello! I haven't worked with software redundancy before, so I was wondering if I could use the CP343-1 Lean modules (which I'm using for the...
1,770
Anbody ever used S7300 with the software redundancy blocks FC100, FB101 etc? I am told that the declaration of IEC timers and associated DB's...
4,055
Hey Ladies and Gents, I'm new to PLCS.net and have a problem with working with the software redundancy of Siemens. What I have: 2 - 315-2...
18,246
Hi All, I am using S7-300 CPU-317-2DP with IM 153-2 for Software Redundancy. I am using Ethernet as Redundant Link. When the Master PLC is...
6,616
Hello all, The S7-3xx PLCs can be connected via Software Redundancy to the redundant ET200M 153-2. This is clearly explained in the Siemens...
2,040
