s7-400 order
Nov 2014
ulaanbaatar
Hello. everyone and experts.
i want to order siemens s7-400 module packets.
so i ordered some modules that cpu, power supply, communication module, digital module etc. But i didnt order s7-400 accessories which RACK,Profibus cable, ethernet cable, battery and blah blah...
Pls help me to choose which accessories need for me?
you can see my ordered module following list.
1.Siemens PS 405/407
power supply - 6ES7407-0KR02-0AA0
2.Siemens CPU 414H
CPU - 6ES7414-4HM14-0AB0
3.Siemens communication module
- 6ES7443-1EX11-0EX0
4.Siemens IM 153-1/153-2
ET200M, INTERFACE IM153-2 HF - 6ES7153-2BA02-0XB0
5.Siemens SM 321 digital input modules
MODULE INPUT S7300 32DI 24VDC 40PIN
6ES7321-1BL00-0AA0
6.Siemens SM332 analog output
MODULE OUTPUT S7300 8AO 11/12BITS 40PIN
6ES7332-5HF00-0AB0
7.SiemensSM 322 digital output modules
6ES7322-1BL00-0AA0
8.Siemens SM 331 analog input modules
SIMATIC S7-300, ANALOG INPUT SM 331, OPTICALLY ISOLATED, 8 AI, 13 BIT RESOLUTION, U/I/RESISTANCE/PT100, NI100, NI1000, LG-NI1000, PTC / KTY, 66 MS MODULE UPDATE, 1 X 40 PIN
6ES7331-1KF02-0AB0
9.Siemens s7-400 pc/ppi cable
6ES7972-0CB20-0XA0
ordered 1 piece of each module. unfortunatelly help me to which accessorries need for me.
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
60
81
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
78
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
108
122
