s7-400, programing issue.
altafjamadar
Feb 2010
pune
29
dear all greatings,
one of my m/c program made in s7 400 is working ok ,but we found a syntex error in FC 2 block due to which only FC2 not go in online mode .is it posible with error .
please guide me.
attachment.php
i agree with moggie, do a compare with the cpu.
And the call function wont work like that, you need something to call like another FC or a FB. And you do not use "end call".
That is what shows up when there is no function that was called. Check if there is this REAL_TO_WORD function in your blocks folder.
dear all greatings, one of my m/c program made in s7 400 is working ok ,but we found a syntex error in FC 2 block due to which only FC2 not go in...
1,350
52
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
54
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
83
107
