S7-400 // Step 7 v5.5 Help
janner_10
Dec 2014
Tewkesbury
1,301
If I go online via the PC Adapter, all the blocks are there and all is good.
If I go online via the CP-443 via IE, all the blocks then disappear.
It's not a big deal, it's just the IE is so much quicker.
Any ideas?
I am going online via the PC Adapter and all is well, if I then go online via the CP-443, the blocks disappear.
I can't really put a different way.
Here is my project:
The highlighted is the offline project, if I go on-line via PC Adapter, then I still see them all.
If I then set my PG to IE and go online through the CP443 - they all disappear when i'm online.
How can I change this?
Those program folders are not associated with the CPU, hence when you go online they are not available - someone has used them as a mechanism for saving the online blocks from CPU blocks folder at various times.
Which is the latest software used to program step7 300 and 400. Thanks in advance
1,834
Hi all Hoping someone could point me to what I'm missing. I have a Step7 multiproject with a two projects in it (I called these B150 and WinCC)...
6,752
H
hello, i have purchased this step7 book used and unfortunatly did not recive the disk that comes with all the examples, if any one has it please...
18
13,173
37
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
47
