s7 400 time stamps
udtwmc
Sep 2005
nottingham
48
i recently asked the question on how to unprotect s7 blocks, i got the answer and have done exactly that. i made a copy of the entire project then proceeded to unprotect blocks via a dbase editor (password to 0)
the original working project is untouched.
basically i have thousands of time stamp conflicts after checking block consistency which simatic can't auto rerpair, which weren't there before i unprotected these blocks.
i get error message 30:18 when opening the object...'the interface of a udt or an fb that was declared as a local variable was changed.
it does tell me how to correct the error by updating declarations but as i said there are thousands of em!
what has happened here and what can i do to magic evereything back to normal and still have unprotected blocks?
cheers
wayne
34
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
45
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
80
97
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
329
