Siemens S7-400 Memory Full
Hi Lare,
Thanks for the response.
The dummy output is currently in the temp area.
Not everything is in OB1. It is quite an extensive program.
I tried putting the PLC in stop before downloading the modified OB1, but that didn't work. I tried to recompile everything, but again that didn't work.
I am back at the customer site next week, so will have a look at deleting OB1 online as LD said earlier.
Cheers
Mark
That is odd. You have before done changes to that PLC?
Not sure how download goes on stop plc and does it still need twice memory, but screenshots of memory used from PLC diagnostic windod should give some clue.
Also as Jesper writes. If you haven't done before changes and it pretty old CPU then it can be flash mem which were cheaper but online edits was not possible.
Can you do online edits on different blocks either?
If Q is outside of CPU model suppurted areas then it is not possible to donwload. But it should give different error message than memory full.
But that was sometimes little bit misleading on old s7. Also it should be probably over 32767 IO address range on 400 before limit.
p.s Also remembered that had once years ago bottleneck memory error on 300 download. Download gived that bottleneck warning and sayed that download can have error. First online edit was success. Other online edits gived bigger error and was not possible. We shutted PLC down and restarted and error goed away. When I looked memory used there was still preserve and error didn't repeated afterwards.
I am trying to quickly find out whether the SIEMENS S7-400 CPU 414-2 (6ES7414-2XG03-0AB0) V1.12 can write to the flash card mounted in it (MC952...
2,927
I am looking for the manual that shows the bit memory avaialbe in different s7-400 processors. For example what is the highest bit address i can...
2,681
Hi Folks, Was wondering if anyone can offer a bit of guidance. I tried downloading to a 414-2 the other day but was stopped due to lack of...
3,296
I'm trying to get a handle on what is "Load Memory". Can any one explain what Load Memory is and how it is implemented?
13,602
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
664
