SIEMENS S7-400 Flash Memory Card Writing Query
TodHead
Sep 2011
Aberdeen
I am trying to quickly find out whether the SIEMENS S7-400 CPU 414-2 (6ES7414-2XG03-0AB0) V1.12 can write to the flash card mounted in it (MC952 6ES7952-1KL00-0AA0) using the
"PLC/Load user program on memory card" command in Simatic Manager or whether I can use the SIEMENS S5 prommer C79451-A3449-A11.
The Siemens documentation suggests this is possible but anecdotal information suggest an S5 prommer was used. I don't have any of this equipment with me just now and need to know before an impending field visit.
Does anyone have experience of this?
Thanks.
You can use the function Download user program to memory card.
I do not think you can use the S5 Prommer, even if there is a slot that seems to fit an S7-400 MC card.
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
346
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
669
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,786
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
I have a project where I've decided to put in a facility to change the PLC time and date through the HMI, as there's no network connection at the...
1,907
