Siemens KTP400 Basic HMI Date/Time field
Puddle
Mar 2022
UK - The Norf
331
I have a project where I've decided to put in a facility to change the PLC time and date through the HMI, as there's no network connection at the installation location.
My date/time edit is pretty much the same as in this document:
https://instrumentacionycontrol.net...9182145_S7-1200_HMI_time_sync_HowTo_e-min.pdf
It works great, except it will not allow me to input a date at all. Whatever I put in, the field turns into ##### and then goes back to zero (1970 for date/time, 1990 for just date).
I've tried splitting off to use seperate fields for time and date and found the time is accepted. I've tried using I/O fields to input the year, month and day seperately and this doesn't work either. I've tried every variety of dd.mm.yyyy that I can think of (HMI language setting is d/m/yyyy) and I've created a new DTL tag that's not assigned anywhere in the project.
Same result using I/O fields and date/time fields. Always using input/output setting.
I’ve not actually checked that. I can write the time so I would have thought it’s writeable, but I’m starting to think this sceeen just doesn’t like me.
Hey Guys, This one is driving me crazy. Has anyone ever encountered this before? I have a KTP400 HMI from siemens and i'm connected to a 315-2...
2,169
Good afternoon. I need help on how to communicate the HMI KTP400 siemenes (using TIA Portal V12) with a MicroLogix 1100 Series B using RSLogix500...
1,572
1,458
281
161
