Available Bit Memory Siemens S7-400
Galaniz
Feb 2012
Corpus Christi
34
I am looking for the manual that shows the bit memory avaialbe in different s7-400 processors. For example what is the highest bit address i can use? Can i use MW1000? What about MW 5000?
There should be a manual that easily answers this i just cannot seem to find it.
Thanks,
Gabriel
Why would you want to use an address that high.
I would barely use memory flags, with mainly FB's and IDB's most memory used would be in data blocks.
PLC, Thanks for the information.
Peter,
This reason is confuscated.
1. We are using the new Siemens 22 inch comfort panels for HMIs. TIA portal supports this model, but WinCC Flex does not. Since WinCC Flex is being "phased out", support for the comfort panel will not be added"
2. We are using two high availability S7-400H for the processors. Unfortunately the bright minds at Siemens have not added the capability to setup redundant processors in TIA portal. So for this I am having to use Step 7.
3. So TIA portal HMI software doesn't automatically integrate with Step 7. Thus all tags must be manually typed in/imported. In a effort to simplify a tag naming convention for this situation all HMI tags will be moved to bit memory under a specifc scheme where the numbder in the hundreds place indicates a specific type of IO or location. When you can easily click on a tag it makes it easier not to make a mistake. In this situation is would seem using Mxxx.x makes it easier to keep track of things.
We have many valves close to 200 maybe and each valve requires several variables. I am now thinking of making a UDT with all variables required for one valve and duplicating it for each valve. Its a pain that the two programs dont work together.
Is there a Bit or Word that I can read remotely, from an HMI in this case, to know if the PLC is run mode, or not? Right now I just have a tag...
2,060
For the RA inclined, the following updates were released today: FT View ver 6.10 (both ME and SE flavors) RSLinx Enterprise ver 5.40 RSLinx...
32,528
Greeting experts, (Let me start with a full disclosure, that I'm not an automation expert and far from Beckhoff/Twincat engineer). I'm writing...
107
Today I was trying to install firmware update to new out of the box CompactLogix processor. CompactFLASH dialog box did not show any revisions...
469
Hello, Not able to find Modicon DO modules BMXDDO3202 in EcoStructure Control expert V15 catalogue. But i can find only MBXDDO3202K. Can you...
539
