ControlFLASH does not "see" available firmware revisions
paulB
Apr 2003
171
Today I was trying to install firmware update to new out of the box CompactLogix processor. CompactFLASH dialog box did not show any revisions available:
Checking folder with firmware kits and relevant revisions are here:
I was trying to use coworker laptop with the same result.
Does anybody know what is going o.
PaulB.
When I checked PCDC, version 36 is only available for that model.
What does it mean? Cannot install firmware below version 36, correct? Please provide link. When searching in knowledgebase could not find anything.
PaulB
Just search for your model and see what firmware is available. When I did it, only v36 was shown and the image I attached showed the available range which was v36 only. I didn't spend alot of time on it...sitting on a plane passing time on my phone. But I would suggest you do the same, download the firmware that's available, install the dmk files and try again.
I would make sure the firmware is actually installed on your PC. Yeah, I see the files there, but are they actually installed? When you launch ControlFlash, select View Inventory and after a couple minutes you can scroll through the list of firmware available on your computer.
OG
** EDIT ** I don't know why Robertmee can't see older firmware. I see all sorts of older versions available to download. My PC has multiple versions installed going based to v20.
OG
I saw them too, but the firmware boxes were all grayed out when I selected multiples. Only v36 was given as an option. I thought it strange, but doing it from my phone may be an issue. That's why I encourage OP to try himself.
I see the same as OG.
You need to expand to see more versions (click the + on the left of controller model number) the picture already shows the - for expanded.
I got the same the second time....very weird. I would still suggest to the OP to download the version they want and install the dmk files again.
Update.
Problem is solved. PLC processor in question is series B. Firmware that resides in PC is version 32.011. I guess not good for series B processor. Had to download version 32.015 and it appeared on ControlFLASH dialog box.
Rockwell tech support helped me with this.
Hello all, I have been tasked with flashing our processors to the newest version of Studio 5000, and have downloaded the DMK file for the...
241
Hello, I tried to install the PanelView Plus 6 700-1500 to firmware 12. On the ControlFlash Plus software, It asked to install the non-DMK. I...
586
Hello, I'm having issue with Control Flash Plus. Last time I used it was two weeks ago and it worked just fine. Today, I cannot pick any firmware...
1,211
Anyone else having issues with ControlFlash or ControlFlashPlus? Neither of them work on my PC anymore. ControlFlashPlus gives a Failed to...
21
6,252
I have a 1769-L32E "A" model that I am trying to flash from v19 to v20. When using Controlflash Plus, I am logged into the Download Center and I...
2,122
