Siemens S7-400 series memory allocation
inst_tech
Jan 2010
Scotland
58
Hi Folks,
Was wondering if anyone can offer a bit of guidance. I tried downloading to a 414-2 the other day but was stopped due to lack of memory.
I've attached a screen grab of the offline info and the online info. This is where I'm getting confused... the program has had countless modifications made to it but the CPU has never been in STOP.
From the screen grabs does anyone know if I put the PLC in stop then use the "download user program to memory card" rather than just hitting the download icon would it clear up some space?
Thanks very much.
Inst_tech
You may free up some space by performing a compress, but the way to free most memory is to delete unused code blocks from the plc.
From the block properties, the code requires 126870 bytes of work memory, but the CPU properties show 156976 bytes of work memory allocated - you must have blocks in the plc that have been deleted from the project. Perform a block compare - this will highlight the differences and will indicate blocks that are in the plc but not in the project (and vice versa). All other code blocks should be identical. Delete the blocks that are only in the plc.
ok, I'll give that a go and see if i can get the bytes to match up. Have had an idea, I think the company I work for has a spare CPU so I'll set it up and try downloaded in the two differnet ways I mentioned.
Thanks for your help.
Inst_tech
Hi What stage of its life cycle, S7-300/400 controllers are at now? In my existing unit, we are using these controller and in near futher there is...
7,082
Hello, I have understanding of AB PLC but I am new to Siemens PLC. In one of the project, I have to go for Siemens SIL-3 hardware that too with...
1,769
Hey guys, I've searched a lot to find the S7 PLC operating system but I couldn't find anything. Can anybody help me on this? and any helpful...
15,982
I'm trying to get a handle on what is "Load Memory". Can any one explain what Load Memory is and how it is implemented?
13,589
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
330
