S7 FC84 ATT function
wasim
Apr 2006
Bokata
Hi all,
I have a strange behaviour with the ATT function. I have a block with WORD data type . When I use the ATT every think is OK. I turned the data type to INT . The commands I wrote usinf the ATT function still working, but When I try to *** a new one always I get an error.
This is the OK code:
A L 0.0
JNB _008
CALL FC 6
EventType :=W#16#302
EventGoodParts:=DB13.DBW68
EventBadParts :=DB13.DBW72
EventTime :=DB13.DBW76
_008: NOP 0
This is the illegal code :
A L 0.0
JNB _008
CALL FC 6
EventType :=W#16#8002
EventBadParts :=W#16#0
EventTime :=W#16#0
_008: NOP 0
The FC 6 is a custom function that gets four WORD parameters and us the TDD function.
What can be the problem, please help.
Regards...
I suggest you read your previous posts concerning Step 7 and word/int problems. You have not commented on the replies given to these previous posts - why ?
I did what you posted, I redeclared the WORD data types to INT and solved the problm. But I still have this trouble problem.
What are the data types for EventGoodParts and DB13.DBW68 ?
How did you create the illegal code you have posted?
The block data types are WORD , the EventGoodParts is a WORD data type.
Anyway , When I switch to STL , and tried to write the code for the same target , then every thing is IK.:rolleyes:
Thnaks allot...
It might help you if you adopted a standard naming function for variables. For example I would use wEventGoodParts as the parameter name.
Other names might be:
bReply
iCount
rMaximumValue
dwPointer
diBigCount
Hello!! help Needed I've been trying to Use FC84 to LOAd Data into table but it dont work. Anybody ever use it with success??? Then i simulate...
4,679
Dear All I am using FIFO with FC84 & FC85 in S7. I have got problem which does not clear the table. Is anyone know any logic to clear the table...
2,174
Dear All I hope you are all well. I would like to know how to use FC84 with FC85. I have a task to start around 10 pumps at round 20 seconds...
2,919
Hi all, I need your help with the TDD (FC84) function. I tried it and every thing is OK, But there is a problem with the data input. I have to...
3,711
Can anyone please explain and show me an example in Ladder how do I use FC84 (ATT) and FC85 (FIFO) in siemens S7-300. As I don't understand it by...
1,833
