S7 : merge a program
glpdrumerx
Oct 2006
Tennessee
48
Hello everyone I am wanting to monitor a program in the plc which is a siemens S7-300. I normally hook-up to the dp port and everything is fine. a programmer added some equipment to our machine and changed the program. he left a copy of the program but i can't log on and still have labels. I know in the A\B world you can merge the program to get labels but not sure what to do here. The programmer wasn't even pluged in the same port I use. Not sure if that is enough info.
You can compare on-line and see what blocks have been changed or added, you can also see what the changes are.
Then you can either manually update the off-line file or transfer from the PLC.
I would imagine you would do a bit of both.
(You can go on-line with a mis-matched project as well).
If you do transfer from the PLC to the off-line file, beware, a Data Block can lose all formats and descriptions and other blocks can end up with line comments (or rung comments in STL) out of sync.
Has the programmer possibly created a PG/PC interface file in the project?? this would only allow access using the configuration saved. This can be altered by double clicking on it.
Also you say he connected to a different port than you?? do you mean he was connected via MPI or was he just connected onto a "piggy back" DP connector??.
If you goto PG/PC interface in control panel, then select CP5611 PROFIBUS, click diagnostics and test the comms are good before opening the project.
Do any of you guys have a merge program you could show me? Like when 2 conveyors join one and it speeds and slows each depending on placement and...
4,097
Hello, besides a post on this site from 2016, I haven't seen any questions or answers regarding this. Is if it is possible to strip the RSLinx...
1,568
Is there a simple way to merge the description off line for RS 5000 Like RS 500 I am new to RS5000 and have several applications running that have...
1,076
dear friend, i use rslogix 5000.I have a program consisting of several ladder diagrams.is there a way to merge them in only one logic diagram to...
1,659
I have 2 different .RSX (RSLinx configuration) files. I would like to make them one file. Is there any way to merge these files?
1,844
