S7 MPI comunicatiom
Manuel Raposo
Aug 2002
Aveiro
Does anyone knows how to devellop or get an OPC client to read and write variables of one Siemens S7-300 within a Visual Basic program?
Alternatively I can devellop a simplified MPI comunication if I know where to get the MPI protocol description.
Hi Manuel,
you can get an OPC server from Siemens (Siemens NET) that will talk with all types of siemens standard networks MPI, Profibus, Ethernet.
I have tried it and it works OK, but i found that the configuration is quite confusing with many different programs for various functions.
There are many other vendors of OPC servers for Siemens MPI, maybe they are more simple to use.
An alternative is Prodave MPI from siemens, it is a package that acesses the the MPI network via a DLL. I have never used it though.
best regards,
Jesper M. Pedersen
If you have OPC-Server for Simatic-Net you can use its ActiveX control in your VB-form. There are propertyes for write and read mapped variables. You can read data with data-changed-event so your VB-application don't need use polling and is as 'Windows application'. OPC-Server polls PLC itself.
Hi I Have new CU320 Module (6sl3040-0MA00-0AA01) for sinamis G150. i want to download Backup config. of old CU320 to new Module with PC Adapter...
531
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
4,984
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,455
Hello guys, I have upgraded the old 318-2aj00-0ab0 cpu to a 317-1ak14-0ab0. After an upgrade there seems to be a communication issue to a HMI...
1,859
Hello automation experts. Do you have any experience with cheaper USB/DP adapters, such as Amsamotion? I would use it occasionaly, mainly for...
1,669
