S7 overall reset (quick question)
Johnny T
Jul 2003
Fife, Scotland
642
Hi
Whenever I've had to do an overall reset on a S7 PLC its just been a case of turn the key (or hold the switch down), let the light flash twice, then let go and turn the key again, the amber light then flashes rapidly and the entire system has had its memory reset.
However, I've just been using a 315 2-DP and this method didn't clear the memory out. I'm assuming its because of the MMC card that was in it.
How do you do an 'overall' reset when there's an MMC card in the PLC?
Sorry if this is an idiotic question and I know that you can just go 'online' and manually delete the blocks but just wondered if there was another way?
Hi Johnny,
Im not sure about other versions but on mine(5.3) goto menu PLC--DIAGNOSTIC/SETTING--CLEAR/RESET in Simatic manager
Hope this helps
Steve
Stevo, thanks for the info mate. So there's no way of clearing the MMC from the key or switch on the front?
PS. Love the avatar... Captain Caveman was superb! Eeeh, they don't make 'em like that anymore... :D
Hold the key in M-RES position until the led stops flashing, release then turn again.
Other than that - go online in blocks and highlight + delete non-system blocks ie. non SFBs then download. The MMC will reload into the RAM though.
Stevo
Can the MMC be formatted whilst in the PLC?
Can the program in the MMC be overwritten with only the system blocks? ie Set up a new project and 'Save to Memory Card...' or 'Download user program to memory card...' under PLC tab of the toolbar.
Foxx, Stevo,
Thanks for that. It looks like to delete the MMC you have to do it through Simatic Manager. This is no problem but it was good to be sure.
The key reset only deletes the CPU memory and if a MMC is present it then loads the contents of the MMC into the CPU RAM.
Thanks for all the replies,
Cheers
JT
PS. Nearly beer time now... I love Fridays!!
I want to reset my S7-300 to default settings (default MPI settings), not just perform a memory reset. Does anybody know if the hardware reset is...
3,854
Dear all, I am facing problem in my SIMATIC S5-100U PLC as it went to STOP mode it is not going back to RUN mode even i reset it...
8,108
Hello everyone, I have been reading this forum for a while and would first like to thank everyone for the helpful information and links to...
17
9,462
I've been programming plcs for several years now and I'm at that point that I want to streamline. All of our machines are custom, but all are...
18
8,757
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
300
