S7 PLC DB to Exel
Gidy
Apr 2004
I have the next question.
I want to view some data from a S7 plc in an exel sheet. I want also toggle some bits in exel. So that I have a simple HMI.
Had someyone a sollution or example how I can do that.
Hello Gidy,
You may think about DDE or OPC. These are methods to get data from an Plc or other device. I don’t know if the Plc can handle DDE. You must check your manual… OPC is an standard tool that comes in all sorts of configuration for almost anything you can think of… Maybe is that an solution.??..
It's not the PLC that has to handle DDE.
Both DDE and OPC are used the same way: the DDE or the OPC server takes care of the communication with the PLC over the dedicated protocol. That's why DDE or OPC drives cost money: the manufacturer has to pay the PLC manufacturer to get insight in the dedicated protocol. As an example: rumours are Siemens charges about 25,000 Euro per protocol. The DDE or OPC server also handles the communication with the client application, but this takes place based on the standard protocols DDE or OPC.
Regards,
OK, you could try the KEPServerEX OPC Servers by KepWare. There's a free demo to download at their website. I have tested one of the previous versions and it looks OK.
Good luck,
I've heard that Siemens has a software, I think it goes by the name "Microcomputing"
I saw a demo for this software, when it was being launched here, some time back, but they were using S7-200 series only. you can check out at siemens's site.
best of luck
R
Hi, i am mew to plcs, would somebody please fill me in on how to get data from a direct 05 plc into an exel program. data consists of temp and...
6,332
Hi all smart and knowledgeable people.I have a hmi connected to 2 Plcs via ethernet.These 2 Plcs connected to control 2 systems in one machine...
89
Hello, We are now working on a software to collet the configuration of different PLC brands ,using a third software to backup all the simens...
89
Dear Experts, I've come across an unusual piece of hardware for AB PLC-5 racks. I mean the NT-1776-HSD-R resolver input module. I have tried...
43
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
232
