S7 PM-E Status byte
Jun 2012
England
64
I am using a ET200s with some normal IO and some safe IO powered by several PM-E DC 24V (138-4CA01-0AA0). I was intending to enable the status byte and use the 1st bit to light some “24V Healthy” indicators on the HMI and desk.
I am getting a strange anomaly; if the status byte is allocated an address above the lowest address of the safety module, then it doesn’t work.
My HW setup:- First PM-E has I address = 0, followed by some non-safe IO, then a PM-E I-address 6, then a safe input module I 10-15, then PM-E address 16, then a safe output module I 21-25.
The first two PM-E status bytes (0 & 6) work fine, but the last one (16) fails to reflect the state of the module’s supply.
Without moving any hardware:-
If I change the address of the last PM-E to a number below 10 (in HW-Config), then it works.
If I change the address of the first two to a number above 10, then it stops working.
I spent hours trying to find an explanation for this in the manuals, but have failed. Has anyone else experienced this or can tell me what is going on?
Thank you
hi all, can you guys pleas help in how to access the status byte for Wago 750-471 Analog input sensor? I am using E ****pit for the first time...
1,937
Hello all, Can some one tell me what's in the devicenet status byte? I have 4 1794-ADN nodes and when I map them there is a 16 bit word at the...
2,157
Hi everyone, any help with the following would be greatly appreciated. I am trying to use the status byte S:53L with an EQU instruction. The AB...
2,638
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
41
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
