Hi everyone, any help with the following would be greatly appreciated.
I am trying to use the status byte S:53L with an EQU instruction. The AB manual states that address S:53L contains the "day of the week" in a SLC5/04 with Operating System 401. I am using a 1747-L541 SLC5/04 with 16k of memory and OS401.
I have checked S:53L many times and it does indeed contain the correct "day of the week". I have lots of available memory.
The manual shows "dynamic config" under classification for that address, I am not sure what this means.
All I want to do is check to see if S:53L is equal to zero. When I try to verify the rung I get an error "Invalid Direct File Offset" and it will not compile.
If I use S:53 as a word with the EQU instruction it compiles
OK (at least shows no errors) but the description is "Discrete Input Interrupt Timer".
Does anyone have any experience with this? Once again, any and all help is appreciated.
