Darren, below is the source code for FC397 which shows an example of using any pointers as well as AR1 (address register 1). FC397 extracts the bit number, byte number and area type for an I, Q or M. It returns "?" if the area is not one of the above. (Other areas can be extracted, I've just not included them in this example). Also included is the source code for FC398 which calls FC397 with four different areas. If you cut/paste this into a source code file and then compile, it should generate these two blocks in your blocks folder. Call FC398 from OB1 and then monitor FC398.
FUNCTION FC 397 : VOID
TITLE =Find byte and bit address of I, Q, or M
VAR_INPUT
pIOAddress : ANY ;
END_VAR
VAR_OUTPUT
iByteAddress : INT ;
iBitAddress : INT ;
cAreaIQorM : CHAR ; //area I,Q or M or ?
END_VAR
BEGIN
NETWORK
TITLE =decode input pointer type and get byte/bit address
L P##pIOAddress; //point to input parameter
LAR1 ;
L B [AR1,P#6.0]; //get address area
L W#16#81; // I area ?
==I ;
JC inpu;
TAK ;
L W#16#82; // Q area ?
==I ;
JC outp;
TAK ;
L W#16#83; // M area ?
==I ;
JC mflg;
L '?'; // not any of the above
T #cAreaIQorM;
JU nof;
inpu: L 'I';
T #cAreaIQorM;
JU nof;
outp: L 'Q';
T #cAreaIQorM;
JU nof;
mflg: L 'M';
T #cAreaIQorM;
JU nof;
nof: L B [AR1,P#9.0]; //lower 3 bits of byte 9 of area is bit address
AW W#16#7;
T #iBitAddress; //bit address
L D [AR1,P#6.0];
AD DW#16#3FFFF; //mask off operand area
SRD 3; //and shift to get byte address
T #iByteAddress;
SET ; //ENO = 1
SAVE ; END_FUNCTION
FUNCTION FC 398 : VOID
TITLE =test FC397
VERSION : 0.1
VAR_TEMP
iBitAddress : INT ;
cArea : CHAR ;
END_VAR
BEGIN
NETWORK
TITLE =call FC397 with 4 different pointers
CALL FC 397 (
pIOAddress := I 9.3,
iByteAddress := #iByteAddress,
iBitAddress := #iBitAddress,
cAreaIQorM := #cArea);
CALL FC 397 (
pIOAddress := "IntAutoLoad",
CALL FC 397 (
pIOAddress := "bBowedRollReverseQ",
CALL FC 397 (
pIOAddress := DB100.DBX 30.6,
END_FUNCTION
