S7 program foreign language conversion
S15DET
May 2005
Charlotte, N.C.
I work with a lot of machinery that was built in Germany with code that was written, obviously, in German. Everything I do is delayed by having to translate symbols, network labels, everything. I don't speak German, so I use a net-based translator, one-word-at-a-time. Is there a software package that will do this for me? If not, maybe I should write one (not that I could)? Would anyone else use such a converter?
I can tell you the problems with using canned software. The "words" used in many cases are technical or "slang" terms that wont be in standard software. I have actually had to break words apart to get their meaning....program from an S7-300 that was written in German and the factory would not translate. You can spend hours trying to translate some programs.
Their are companies that do technical translations but they are not cheap.
I may have to retract this statement. It was several years ago when I was doing the translations and had problems. I just used Babelfish and it now translates the terms much easier and better than it did in the past.
Babelfish will allow 150 words too:
http://babelfish.altavista.com/tr
I am going back to college to obtain my BSEE, one of my first subjects that I WANTED was German.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
70
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
60
246
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
33
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
552
