s7 Symbol table
kirso
Jan 2005
Doncaster
51
Is it possible to copy or import just the used addresses out of the program, so these can be used in the symbol table?
I am writing the symbol table in an old program and its a pain to enter each address one at a time.
I would like to load up just the addresses used and then enter the symbol/description.But up to now have not found a way to do this.
The xref facility will tell you which I/O is used in the program is that what you are after ?
Right click on the block folder to get the drop down list.
thanks for the reply fellas.
But I wanted to be able to import the info from the X ref list to the symbols list.So it showed the used addresses.As it stands i have to open the symbols file and enter each symbol and comment and then the address. I found this to be a pain cos I was having to go back to the xref list to see what was in use in the program.
It didnt help that the drawings were also a mess.
I thought if I could import the addresses from the xref that would be a lot easier.
Or is it poss to enter symbols in xref list ?
Hi Kirso,
I think that symbols can not be edited via xref.
One solution is also to go through the program network by network and edit the symbols like in the first picture.
Second solution is to modify symbols in Hardware config like in the second picture one module at a time.
Other option is to export your existing symbols from symbol table to Excel-file and then modify the file in Excel and import it. I use the DIF-format.
Theres few ideas.
I have a running project that will now be duplicated with some changes. Theres been lots of changes of in and output adresses in symbol table. The...
1,512
Afternoon guys Some of you may of seen my roller door project that LD was helping with a few months back. Well I started to try and learn to...
1,382
Hi I am working with a siemens S7 PLC which was not having comments in the program.There was a similar program with symbols but having some...
3,694
Is there a way to convert or export Step 7 Symbol table to RSlogix 5000 Program Tags
5,528
Hi, I am using S7 300 plc can we Dwnload the symbol table in plc by simatic manger? :mddr::mddr::mddr::mddr::mddr:
2,801
