S7 - WinCC - Tags - Import/Compilation
fieldprog
Oct 2006
Burgenland
43
Hello there,
I´ve got a S7 Project in the Simatic Manager right now, and want to
transfer some tags into the WinCC - Manager.
I did this allready one time, but I don´t remember the whole
procedure to compile them.
Any suggestions?
fieldprog,
I dont bother transferring tags. There is a tag manager which you could use to replicate your tags but thats not very efficient. When you want to use a tag, eg to write to a bit in the PLC, I would just go to the properties of a button and pick the tag out of the S7 PLC for the relevant event. WinCC will then create the tag for you.
If you are doing alarms then I tend to transfer a word at a time and then pick the individual bits in discrete alarms.
This is way I do it:
first of all, U need to connect wincc project with step7 project.
(WinCC) Project->Integrate in Step7 (navigate to project folder)
To add tag from step 7 go to wincc tag table select Symbol cell and in that symbol cell click downarrow where you get tree list of S7 project. Navigate to symbols and pick one U like most :)
Easier way to do it is directly in tag field of some properties.
I hope this will help someone
Hi all! I am a new user of Siemens S7. How to export DB and Symbol table from step 7 and import to WinCC Explorer? I have one STEP 7 project...
7,763
Hi i'm a new wincc user and i need help to solve this problem: I had exported tags from Wincc Flexible 2008 SP2 to a .csv file, and now i need to...
3,482
Something simple and stupid I'm sure.. I'm trying to export my tags from an existing project, so I can modify to my new needs. All help files...
7,694
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
75
Need to add new tags to some recipe inside a Wincc Tia Hmi . Do we have an option to download the recipe , with the newly added elements ...
246
