SCADA for ZELIO
bouklas
Mar 2007
Thessalonikh
HI once again!
I have and one more question!
I have one Zelio smart relay for one final work for my university.
Does anybody know if i can use any scada system?
Till now i didn't find something
Thank you once again!
Not highly likely. Smart relays are not designed for communications, they are designed for simple applications as relay and timer replacements.
I do know the Mitsubishi E-terminals have drivers for the Mitsubishi smart relay (Alpha) but other than that, never heard of a SCADA system which has drivers for those cheap devices.
I Have a Scada for Zelio
Scada comunicated with serial port (using USB programing cable) I you want test it, call me. :)
No need ethernet module (modbus/tcp ip Zelio) just need the USB cable and any Zelio with BFD program support.
Resgard.
Javier
hello ,
I just realized a mini-scada for Zelio and android,you can work with the bit or word.
You'll find on google play, or send me an PM to receive a free trial
Alan
HI once again! I have and one more question! I have one Zelio smart relay for one final work for my university. Does anybody know if i can use...
2,798
2,090
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
67
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
78
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
73
