Scada Newbie - (Tags, addressing devices)
demuso
Dec 2008
Wolverhampton
Hi guys,
This probably is a very silly and simple question, but I have about 56 devices all of the same type. (i,e use the same device addresses but at different IP addresses). Do I have to declare each tag for each device in the tag variable list, or is there a quicker way to get around this?
Any help would be much appreciated.
thanks =)
Tentatively, Yes.
At the very least, you probably need to declare about 56 different communication topics in you OPC/DDE server (If you have one). Then you could possibly get creative in the HMI by scripting to scan through the servers (If your HMI supports this), or blind aliasing a generic tag to various topics (if your... Wait... Getting a thought here, oh yah... MORE INFORMATION NEEDED FOR A VALID RESPONSE).
Um. I'm connecting to around 56 Mitsubishi PLC devices - each with the same set of functionalities. Each device has a set of variables at the same addresses e.g. Comms_status at address M1000. Do I need to make 56 individual tags for this or is there a way to use an address label and device connection?
Hello Guys, Newbie with Siemens here. I will be configuring and deploying for a project of mine for WinCC redundancy. I have read this article...
7,327
Hi all... I have a project that uses SCADA. and I am very new with this SCADA. I will use LG PLC with type Master K200 or K300 CPU. does anyone...
6,955
D
Scada; Does anyone know of a REALLY cheap or better yet free Scada. I'm just messing around with a small home automation project and I'm looking...
4,971
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
47
