SCADA quries
aju
Jan 2005
22
Hello,
Please reply me for some quries
1. Does Citect have dynamos?,in which we can have pre defined
animation, onlly tag has to be defined when we drop it to the
screen like iFix
2. Does Citect have an event based schedule like iFix?
3. Does Citect have lookup (threshold) tables?
Citect does not have dynamos but does have Genies and Suoer Genies that can be used for pop ups etc. You can also program your own pop up windows etc. It is quite easy.
Citect has events.
Have not had a need for look up tables so cannot answer that one.
Why don't you contact them direct and ask.
www.citect.com
By the way, Citect is by far my favourite SCADA. The best trend pages in the business. Supports VB, ActiveX etc etc. Lots of drivers and you do not have to buy them one at a time. They come with the package.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
47
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
67
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
254
