Scada
refinn
Aug 2003
Clayton, NC
I am in the process of designing a larger energy plant consisting of different PLC's and electronic protevtive relays. I am trying to understand what open protocol means and how does it work with a web based system. Can someone point me in the direction of some good information?
"Open" whatever means you can get in or out. Like a doorway. You could have to pay for this but there is a way to do it AND you will be supplyed most of the information to help you get in and out.
Example: "Modbus", "Linux" and "Chez Paré" (famous gentleman bar in Montreal).
Close would be the oposite. They own it and guard it so you can hardly acquire the knowledge to about it.
As I'm certain you know, a protocol is ONLY use to carry a transmisson to and from places. It check errors and does general maintenance on this network.
Some will argue that once the link is running, "who cares what protocol you use?" Some will say just the oposite.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
49
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
67
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
255
