Scada
You can use C, C+, C#, VB, Java, or even a scripting languages like Lua, Python, or AngelScript.
You can find loads of information on all of these on the Internet.
HTH :)
I think these things come in waves; this week we've had first-time posters who are developing their own OPC Servers and their own SCADA, and just in October we've had posts seeking to build their own PLC and their own VFDs from components.
Flash, Modbus is the simplest and most common serial protocol in the industry. Start at Modbus.org to learn about it.
There are hundreds of "SCADA" software packages. Some of them are very low cost or even free.
There are quite a few Modbus libraries for various programming languages, both on embedded and PC-based platforms.
I very strongly recommend that you evaluate commercial and open-source software libraries for your needs.
If you can explain what sort of task you are trying to accomplish, I'm sure the Forum has members who can help guide you in more detail.
Gelecek OPC Controls in .NET
You can use Gelecek OPC HMI Componenets.It is very easy.You can use them with c# or VB languages. By the way You dont need to write code.
http://www.geleceksoftware.com
You can try demo version. Each components are OPC Client too.
(y)
It's project time at the local tech school ;)
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
28
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
54
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
67
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
256
