ohcaptainmycaptain
Hello, I’m still a novice when it comes to plcs, and I’m currently facing a problem I need help on. I’m on site at the moment, and connected to the scadapack using telepace studios.
There was a power issue that we fixed at the start, but we have no idea how long the scada pack was without proper supply. When we got it powered up I connected to it, but the program is missing.
I’ve checked program status and it says there’s no program. When I tried to check the controller ram battery voltage status (using edit online) it says that the program in the scadapack and the program in telepace are different. I tried to monitor and the device and it said the same.
The only thing I can think of is to write the ram voltage register to the scadapack, but I’m afraid to do so on the off chance the program is still there. If anyone could help, or just just shed some light on the problem, I’ll greatly appreciate it!
Thank you
Thank you
